Hi all, may I know why the SNAP PAC R2 controller will lost connection from time to time? and it was happened around 2-3 sec.
Thanks
Chen
Thanks
Chen
Something with your network, or some contention in your charts.
Does every single one of your charts have a delay in every single loop? This is a must.
Regarding your network, you should work with your IT guys to ensure better connectivity.
Yes, there is a 2 msec delay on every single loop. Is that sufficient?
by the way, i’m not running any control chart in the controller. I was using softpac on my workstation instead.
and i notice the controller stat LED turn red while i lost the controller connection. After the stat LED turned red, the controller will then restart itself.
Check for 5.1 volts on the rack to the controller.
Yes, i have checked on that before.
Coincidence, I have a SNAP PAC EB2 at site, and it works fine after i swapped it.
My next step will be replacing another SNAP PAC R2 controller.
