Setup looks like this,
Snap pac r2
Snap enet s64
Snap enet s64.
We dominantly use AB hmis and plcs, but part of our refrigeration system includes the aforementioned option setup. I spoke with support several times this week about moving float data into the scratch pad in order to retrieve several temperature values to an AB plc.
I went into config, added an action block to move the data. Created two variables. Went to debug and now I’ve lost the connection to the second s64. I cannot get it to connect. I reverted my changes and deleted the two variables. Now I still cannot get it to connect to the s64 and the PAC runtime will no longer open locally. It begins the search for scanners and stops. The refrigeration system and display have been in process for several years.
Any help would be greatly appreciated as I really need to get this running promptly before production fires up.
After reverting all changes I have tried to ping the controllers. The r2 and first s64 ping fine. The other s64 responds with expired in transit.
I ended up getting the old strategy back to running. There were some issues due to running dual networks. Does any have any samples of moving floats to the scratch pad?
