Hi,
I have recently downloaded the iPhone App and am having problems with the demo on the Opto site.
I can go to Internetio.com and get to the device (i.e… para 7 in your technical note form 1966-120724). However, when I touch Retrieve Data (Para 9) the phone sits there and nothing appears - no listing of variables. The same thing is happening when I try to access a unit in the field.
Any suggestions?
I am connecting to the internet through an Apple Airport Express
Peter
I look after the internetio.com site and demo panel and such, so I just had a quick look at it and it all seems Ok from here.
I then jumped onto the site using my Android phone running aPAC, and it works as it should.
Sadly (thankfully? I am not much of an Apple guy, so I will need to track down those that are here at Opto and see what happens when an iPAC device hits the site.
At a guess we need to make sure that you have not turned on any VPN settings on the iphone… the fact that its doing the same thing over the net as intranet is suspect in my mind…
Also not sure if there are any NAT or such settings in the Airport Express that might be diverting the return packets…
Lastly, drop support@opto22.com an email and see if those guys have come across this before.
Thanks Ben.
Support called me this evening. Apparently v1.04 has a problem which v1.05 will fix. Hasn’t been passed by Apple yet, so I will wait until 1.05 comes out.
