I’m using PAC Display 9.5d Basic on a project and I would like to send emails using it’s email feature. I have had no luck so far and Tech Support hasn’t been very helpful on this subject.
Has anyone successfully been able to implement the email function using 9.5?
If so do you have an example of your configuration?
Yes I’ve successfully done this multiple times using groov. This customer doesn’t have groov however and would like to use PAC Display to do this if possible.
Off the top of my head (the manual might have some helpful insight) PAC Display uses Outlook Express Lite to send its emails, so if it not a network issue, then it must be on the PC configuration side of things.
Can you send an email via Outlook Express on that PC?
I’m pretty sure outlook express is as dead as windows XP now. PAC display used to require a mail client to send e-mails, but now can use some built-in providers on 9.5. I believe 9.6 allows you to setup display to talk to any mail server, but I haven’t tried this yet.
So are you using the “System Default” selection or one of the built-in mail services? For system default, I have used Mozilla Thunderbird successfully in the past.
We can’t use 9.6. I verified that we can successfully do so using Default but then Outlook asks permission to do such. Is there a way to circumvent Outlook asking if it’s ok to send that email? That would be a suitable workaround.
I had the same issue with outlook 2007. Luckily one of our IT people knew of a registry edit that made the outlook issue go away. I’ve since been forced to upgrade? to 2013 version of outlook and alarms no longer work in pac display.I’ve tried custom, using same info I use in Groov, but wont connect to server. When I use default
I get the Outlook error of old.I’m using 9.6 pro
I was, but a little fumbling around with the security settings and it works. Now the big question is is there anyway to get this to work outside of using outlook. It’s an additional hurdle and extra money it would cost for every computer to need outlook.
Once again, groov is a working alternative but I need to completely verify what I can do in PAC Display.
Also, would this be easier or more viable to do in PAC Control?
You SHOULD be able to setup display 9.5 to use any e-mail provider directly (the custom option) - it works for me using our in-house email server.
Failing that, you could setup Mozilla Thunderbird on each computer instead of outlook, which is free.
If it were me, I would really try to get the PAC Display custom one working, as that is a lot cleaner.
If you are having issues sending e-mail to your mail server through PAC Display, then I think doing it through your strategy will be even more difficult - so if you are going to have Display running anyways, I would stick with that.
