For [B]x[/B] = 1 to 4
MyTag[B]x[/B] = 1 // Indirectly addressed variable’s value assignment.
Next
MyTag[B]x[/B] would reference variables MyTag1, MyTag2, MyTag3, etc.
instead of…
MyTag1 =1
MyTag2 =1
MyTag3 =1
MyTag4 =1
Values for “MyTagx” will almost always will never be set in a loop at the same time, but just wanted to illustrate the idea to see if this sort of thing is possible with Optoscript.
Have you considered defining MyTag as a numeric table?
For x = 1 to 4 Step 1
MyTag[x] = 1;
next
Edit:
For bonus points, you could put a list of more descriptively named variables into a pointer table, and then cycle through the pointers in a similar command:
I guess we are talking about two completely different addressing methods. I started off by providing a bad example (indexed instead of indirect which is what I was wanting). What you are referring to is Indexed addressing. i.e Table/Array access or referencing.
What I am wanting is Indirect Addressing of a variable. For an example in a table say that I have …(does not have to be a table. Can be any valid Variable or I/O Point declaration).
Tag[0] = 0
Tag[1] = 1
Tag[2] = 2
Tag[3] = 500
Say I have another variable (could be a variable or a variable table, Input or output data from I/O racks)
nVariableX = 3
So if i were to indirectly address a variable to get at it is value, Expression would be written as;
[B]
NewVariable = Tag[nVariableX][/B] would give me a value of 500 for the [B]NewVariable[/B]. Which is what the value of Tag[3] is.
So Tag[nVariableX] is [B]INDIRECTLY [/B]referencing Tag[3] based on the [B]value[/B] of nVariableX.
Thanks for the links and Pointers. (No Pun Intended)
is standard functionality. If you want NewVariable to follow the value of Tag[3] if it changes, then NewVariable needs to be a pointer.
pNewVariable = &Tag[nVariableX]; //pNewVariable will always return the current value of Tag[3].
you could take it further, but it requires two lines of code…
nVariableX = 2; //nothing happens
pNewVariable = &Tag[nVariableX]; //pNewVariable now returns the current value of Tag[2]
I might still not be understanding correctly what you want, so here’s another example with pointers (might be more useful to just post a picture of a rabbit with a pancake on its head):
Let’s say you have i32’s “nX” and “nY”, and pointer “pA”.
nY = 6;
nX = nY; //nX now equals 6
pA = &nX; //pA now returns 6, referencing nX
nX = 5; //pA now returns 5
*pA = nY; //nX now equals 6
Edit:
In Page 18 of this document, it looks like this pointer example matches up to the indirect addressing example, so maybe this isn’t too far off…
