This is probably an odd request, but it looks like Node-Red is capable of creating some custom web pages (using HTML) with the HTTP endpoint node. I have some existing web pages using HTML from another application, and this would save a bunch of time from having to re-create everything in Groov.
I was able to get the nodes below to work on a node-red instance running on my desktop, but no luck on my EPIC-PR1 (404).
@psantoro3 Oh, and you can remove or edit the ‘ALTA Web’ firewall rule you show in your screen shot… On EPIC, Node-RED is through port 443, so there is no need to expose 1880.
There is nothing listening on that port (1880), but best practice is that you don’t open any ports that are not needed.
