I’m trying to read a text file off of the user file area of an Epic controller with my PAC Control strategy. The file is called ‘Config.txt’ and I’ve uploaded it to the Epic using the Groov Manage interface. I placed it as an unsecured file.
I’ve read these types of files before on a PAC Controller and in that case the comm handle to open the file for reading would simply be:
“file:r,Config.txt”
The above is not working when trying to open the communication handle. Is there a folder location where the unsecured files are stored that I’m missing here? I’m unable to get my Open Communication command to work.
Here is a working chunk of code to append a line to a txt file on the Epic in the unsecured file area. I am running Epic firmware 1.2 Earlier versions may experience problems with the file write, see kb87590
// here is the data string to append to the csv file
taccDataString = "10/11/2018,02:48:15,123.4,56789.1" + Chr(13) + Chr(10); // Data line with a carriage return / line feed
// build the header line. This is only used if the file doesn't yet exist. Its nice to have a header at the top
taccHeaderString = "DATE, TIME, FLOW, DAYTOTAL" + Chr(13) + Chr(10); // Header with a carriage return / line feed
// see if the file exists by trying to open it read-only
// if it dosn't exist, write a header line
taccFilespec = "file:r,/home/dev/unsecured/testwrite.txt";
SetCommunicationHandleValue(taccFilespec, tchFile); // read only
taccWriteStatus = OpenOutgoingCommunication( tchFile ); // open the handle
CloseCommunication(tchFile); // close the file handle and check status
if (taccWriteStatus <> 0) then
// write the header if there is no file yet
taccFilespec = "file:a,/home/dev/unsecured/testwrite.txt"; // open for append or create
taccWriteStatus = OpenOutgoingCommunication(tchFile);
if (taccWriteStatus == 0) then
taccTransmitStatus = TransmitString(taccHeaderString, tchFile); // write the header line
endif
endif
// Write the data line
taccTransmitStatus = TransmitString(taccDataString, tchFile);
endif
Code Comments -
I’ve hard coded the data. You would build the data line with your real values.
I’ve also hard coded the filename, and in several places at that, which would not be good practice.
I’ve got some error handling, but not all conditions.
The file is open read-only to determine if it exists. If it doesn’t the header line is written. Then the data line is written.
