Is there a way to switch a Groov back and forth between PACs without having to redo all your tags? I could have sworn I’ve done this in the past.
Must be the time change…
Thanks
Thanks
Assuming your PACs are running the same strategy, you can simply change the Address or Hostname that your groov project is pointing at.
In Build mode, open the Configure Devices and Tags dialog, find the PAC you want to switch, and click the Edit Device button. You can change the address there.
That’s what I thought and of course it works. My brain just shut down.
Thanks Jonathan.
