PacProject 10.3
When downloading a strategy we get the checksum compare, is there a way to store this particular value into a variable?
PacProject 10.3
I don’t think there is a supported command.
You can open up a comm handle to port 22001 to localhost and use the TransmitReceiveString command. EOM character would be 20h (space) and the command to transmit would be “CRCSTAMP” + Chr(13) - That will return a string with the ASCII checksum - there will be a couple leading null characters you will need to remove.
Thanks for reply! I understand…some…of what you described. Hah. Let me play around with it and see what I figure out. Thanks again.
Here is some sample code that gets the strategy checksum:
SetCommunicationHandleValue("tcp:127.0.0.1:22001", chLocal);
nCommStatus = OpenOutgoingCommunication(chLocal);
if(nCommStatus == 0) then
SetEndOfMessageTerminator(chLocal, ' ');
sTransmit = "CRCSTAMP" + Chr(13);
nCommStatus = TransmitReceiveString(sTransmit, chLocal, sReceive);
if(nCommStatus == 0 and GetStringLength(sReceive) > 2) then
//Trim null padding
GetSubstring(sReceive, 2, GetStringLength(sReceive) - 2, sStrategyChecksum);
endif
CloseCommunication(chLocal);
endif
