We are having an issue where running a StartOnPulse is causing the memory in our controller (S1) to reset, running version SW version10.2 and FW version10.0F
Anyone else encounter this issue?
Please email our support group with this issue.
support@opto22
You will get a ticket number and will be able to track it to resolution.
We have a ticket in for this issue and they are looking into it, I was just curious if anyone else out there had encountered this issue and any sort of resolution they had reached? As of now we are currently working on manually changing the code but it’s used in 184 instances in the logic so it’s quite time consuming and installed in a running process that is now down with production halted.
