I am attempting to download a small strategy to a PAC Sim controller. I created a .cdf file; but when I download I get “ERROR: Ethernet socket error:Socket is not connected.” Code: -10057.
Since the controller is software with a loopback address of 127.0.0.1, I don’t understand what or how the socket is not connected.
Can you first use PAC Terminal to inspect the controller?
This will tell you if the controller has installed and been configured correctly… Or if the problem is with the .cdf file.
Ok, so PAC Sim is either not installed or not running.
There should be an icon down in your task bar near the time (you might need to click on the ^ to see all the icons you have installed).
If there is no icon, then you need to run SoftPAC Monitor from the Windows start menu to start the control engine.
