I am trying to get SynchronizeClockSNTP to work.
If I use for URL udp:timesrv:123 I get an error -450 which is DNS can not resolve.
I have tried numerous combinations of this including the fully qualified domain name with no luck. Now that udp: in the front looks suspicious to me as not normal. However if I leave it off I get an error -46 Invalid string.
I tried putting in the IP address of the time server and get the same -46 error.
The standard port is 123 and the NTP standard also says use udp, so I wonder if this command should be revised to accept a more generic URL.
Any suggestions other than right my own script to do this?
Regards,
Jerry
