Setting Resolution of External Display connected to EPIC
How does one set the resolution of the external display connected to the EPIC?
At the moment, EPIC asks the screen what its resolution it is and sets itself to match (or as close as possible).
When the new 1.5.0 firmware is released in mid to late December you will be able to select a resolution from a drop down list. You will also be able to ‘zoom’ the display to make small displays look a bit better.
Lastly, you will be able to use some restive touch screens as there will be the option to calibrate the touch on those types of monitors.
