Sounds like a root certificate problem. Make sure you’ve put the correct root certificate on the controller in the correct location.
[U][B]Tools to Put the File on the Controller[/B][/U][INDENT][B][I]PAC Manager[/I][/B]
You can use PAC Manager, but the dialog is a bit unclear, so it is easy to end up without the file on the controller and instead have a file that was supposed to be a folder.
[I][B]FTP Client[/B][/I]
It is best to use an FTP client, like FileZilla:
https://filezilla-project.org/ or
https://filezilla-project.org/download.php?type=client
[/INDENT]
[U][B]File Location[/B][/U]
The correct location is to put the file on the controller is found in the PAC Control Command Reference under this topic:
Chapter 10 “Programming with Commands” > “Communication Commands” > “Sending an Email” > “Registering a Root Certificate on a SNAP-PAC Controller”
The correct file location on the controller is:
/pki/root-certs/
If using PAC Manager > Tools > Maintenance > Upload File to I/O Unit, the “Filename” field is the path and filename where the file is located on your hard drive. The “Destination” field is where you want to put the file on the controller. This requires the full path and the filename, for example:
/pki/root-certs/Equifax_Secure_Certificate_Authority.cer
[U][B]Store Files to Flash[/B][/U]
Be sure to store the files to flash on the controller using PAC Manager > Tools > Maintenance > Save Files to Flash.
[U][B]Reboot after Storing Files to Flash[/B][/U]
Be sure to restart the controller after storing the files to flash using PAC Manager > Tools > Inspect > Status Write > “Restart Device from powerup”.
I hope that helps!
