Hello,
is there any example code how to read/write on a RS232 or RS485 module based on the “C++ OptoMMP Software Development Kit for SNAP PAC” code? We have SNAP-SCM-232 and SNAP-SCM-485-422 modules.
Thanks.
Hello,
Thanks.
Hello uca,
Welcome to the OptoForums! I’m not sure that SDK is what you need for what you’re doing – unless you’re just trying to configure the modules (which is an OptoMMP function, which could also be done using PAC Manager).
How best to read/write your serial data to/from that module will depend on what else you have going on there. What brain/controller do you have on that same rack w/the modules, perhaps SNAP-PAC-EB2 or SNAP-PAC-R1 or 2?
FYI – once you have those SCM modules configured, you can access them from anywhere via TCP/IP using the IP address for your brain/controller, and the port number of the particular module & port (those numbers start at 22500 by default).
Can you tell us a little more about your application?
Cheers,
