I am trying to read an IDC16 module’s input via the OptoMMP DLL. I am finding that the results are erratic. I have a voltage applied to one of the inputs and sometimes I see the input as being “active” and other times I don’t. I don’t know what I did but it started working. I also noticed in PAC Manager using the inspector, the Refresh button would sometimes clear the display area without rewriting the input values.
Are you using an Opto 22 power supply for that rack? I’m assuming here you mean you have a SNAP-IDC16 on a rack w/a brain, perhaps a SNAP-PAC-EB2?
Our power supplies are more expensive than others, but they’re also more likely to give you a nice consistent voltage that the brain & modules need.
If that’s not it, you’ll want to contact our Product Support team (it’s free!). They’ll have you use PAC Manager to have a look at the “Status Read” area which shows your hardware/firmware versions. Also, toward the bottom (if you scroll down in the Status Read area) you’ll see info like this that can be helpful for troubleshooting:
0xFFFF F030 007C Smart Modules Present 0x0098
(analog, serial, etc.)
0xFFFF F030 011C PID Loops Supported 96
0xFFFF F030 0148 Digital Modules Supported 16
0xFFFF F030 0100 Arcnet Reconfigs Detected 0
0xFFFF F030 0104 Arcnet Reconfigs Initiated by I/O Unit 0
0xFFFF F030 0120 Arcnet Transmit Attempts Since Powerup 2172696
0xFFFF F030 0128 Arcnet ACKs 2172683
0xFFFF F030 0134 Arcnet Timeouts 0
0xFFFF F030 0124 Arcnet Other (node not found, etc) 13
0xFFFF F030 0130 Arcnet Timeout Value (msec.) 0
0xFFFF F030 0138 Arcnet Receive Interrupts 2172683
0xFFFF F030 0110 Ethernet MAC Resets Since Powerup 0
0xFFFF F030 0114 Dig. Output Point Resets Since Powerup 0
0xFFFF F030 0118 Dig. Interrupt Failures Since Powerup 0
0xFFFF F030 0140 Analog & High Density Digital Scanner 0.990 msec/scan
0xFFFF F030 0144 4-Channel Digital Scanner 1.000 msec/scan
0xFFFF F030 00C0 Module 0 - Times Discovered 0
0xFFFF F030 00C4 Module 1 - Times Discovered 0
0xFFFF F030 00C8 Module 2 - Times Discovered 0
0xFFFF F030 00CC Module 3 - Times Discovered 0
0xFFFF F030 00D0 Module 4 - Times Discovered 0
0xFFFF F030 00D4 Module 5 - Times Discovered 0
0xFFFF F030 00D8 Module 6 - Times Discovered 0
0xFFFF F030 00DC Module 7 - Times Discovered 0
0xFFFF F030 00E0 Module 8 - Times Discovered 0
0xFFFF F030 00E4 Module 9 - Times Discovered 0
0xFFFF F030 00E8 Module 10 - Times Discovered 0
0xFFFF F030 00EC Module 11 - Times Discovered 0
0xFFFF F030 00F0 Module 12 - Times Discovered 0
0xFFFF F030 00F4 Module 13 - Times Discovered 0
0xFFFF F030 00F8 Module 14 - Times Discovered 0
0xFFFF F030 00FC Module 15 - Times Discovered 0
I am trying to use a SNAP-PAC-R1 on a SNAP-PAC-RACK16 with low density DI modules (more than 8) as a master and a SNAP-PAC-R1 on a SNAP-M64 backplane as slave. Every second there are “arcnet reconfigs detected” and “Arcnet Reconfigs Initiated by I/O Unit”. Power is 5.01 V.
Although according to te optoMMP protocol guide it says:
“ARCNET reconfigs initiated by I/O unit. Error on the rack’s ARCNET
bus. (Does not apply to E1s or E2s.) Not a concern unless it happens
frequently. If there are no analog, serial, high-density digital, or PID
modules on the rack, ignore it. If there is at least one of these modules
on the rack, make sure the rack has adequate voltage.”, I am concerned that it is not going to work.
Right now it is running in test configuration. Can you assure me that this will run in the real world?
regards, Berry
Have you contacted our support group with this? (support@opto22 dot com)
They have some deep knowledge of the error you are seeing and may be able to help you resolve it.
