I’m not sure which SDK you are using, or if it even matters, but if you are reading your input from the I/O via the mem map address (MMP), then you can do the same with the host name.
Just point your SDK to the correct address and you can read any of the PAC Manager locations.
Here is a screen shot from Pac Manager that shows the MMP address. In this case, I called my controller bensLC.
