Is this a bug or a problem with my system?
If I open a page this happens on multiple tags. Sometimes it resolves in a second or two, sometimes I have to switch to a different page and then come back and that usually fixes the issue.
Check the groov log. It usually means an issue with the network… There is a lag between when groov polls the device and when the device responds… the log should help point you in the right direction to start looking.
