Hi I would like to report a bug with regard to importing tags and I/O units in PAC Control PRO 9.3c. If the import file contains a B3000 unit then it is impossible to import the configuration… even if you create a B3000 I/O unit then export and then import… it fails, this however does not happen in PAC Control PRO 9.2, will there be a fix?
