I am trying to figure out how to connect to Groov Epic remotely. I have an AWS instance set up running and OpenVPN. Under the grove Manage it shows I am connected but I am not able to see the PLC when I scan through Codesys. Please let me know if you see anything wrong?
Try this… On your PC that you are using to access the EPIC, ensure that you are routing ALL Internet traffic through the VPN. It sounds like not everything is going out the VPN from the PC.
