One question after another
Using IDC5-i, I hope that when the external signal is changed from 0V to DC24V, can the delay in the controller change from 0 to 1, for example, 3-5 seconds delay, without using timer variables. Can you modify the parameters through PAC Manager to achieve them?
Thank you!
What delay are you talking about? Is this a delay command in your strategy?
Also, which parameters do you want to modify through PAC Manager? The length of the delays?
