So, I only want to save information when a confirm button is pressed (write the data to a string). Also, I don’t know how to make arrays of strings. Do I have to make it a table? I just made a table for my “array”. Usually I’d have a command in C, for instance, when a button is clicked, whatever I wanted would process, “OnClick”. Is there a way to do this? Same thing with a button pressed down time, GUI stuff like that.
Thanks.
First of all, yes, a table is what you’d use for an Array.
Those “events” like “OnClick” you might have used in other programming environments, don’t really have an equivalent in PAC Display and/or groov. You pretty much write or read values. I’m guessing here you’ll want to do something like: write a 1 to a variable perhaps called nWriteTableFlag or some such. Then, in your strategy logic, you could see if nWriteTableFlag is 1, if so, set it back to 0 (before you forget) then do the “write data to string,” whatever that means to you. Then you’d loop back around to check that flag (after a short/reasonable delay, of course).
What do you mean by “write the data to a string”? Perhaps copying values from something you’re showing in the GUI to something that’s being logged elsewhere? (Can you tell us the “bigger picture” here?)
Kind of a late response…but, my user name originates from a character in a cartoon/anime called Love Hina. She/he is a flying turtle, and I thought that was cute, so I have been using this SN for things like games, and just continue to use it as a forum name so that I can remember it.
My application is basically a program that checks the status of pressure in containers and controls when to start/stop filling with pressure, in a nut shell.
