I’m pulling an unsigned integer from a modbus device unscaled. It looks like this:
I’ve created tags in Groov that look like this:
My Groov page in Build looks like this:
The end result looks like this:
Why am I not seeing my raw value of 4006?
Thanks
First off, Try reading register 359, also check your device setup. The significant bits and base one/not base one addressing will effect what you see/read.
I thought I was home free but my scaling isn’t working. Any ideas:
Scaling is kind of broken/wonky right now. Especially going from 16-bit unsigned to a float. You can get it to work by:
- Deleting the gadget
- Deleting the tag
- close/save settings
- recreate the tag with correct scaling
- recreate the gadget.
Read Only is mostly reliable, read/write works (kind of), but expect strange results.
That worked. Thanks!
When did that happen? Never had an issue before.
Around the 3.4-3.5 update… I think…
