I recently got a groov Epic PLC and I would like to install a pack of Nodes to begin a project. The fact is I can’t do it.
Here is how I set up my installation:
Typically on EPIC eth0 is used for the internal network and eth1 is used for the side facing the public internet. You could either switch that around or look at changing the Gateway and DNS order on the network configure page (lower numbers have higher priority). Also check your firewall rules as they may not be what you want.
