In PAC Control Professional R9.3b, in debug mode, when you double-click on a variable to look/inspect it, the window locates itself in the upper-most left part of the screen on top of run and stop strategy buttons. Is there a way to set the default location to the center of the screen or anywhere away from the stop strategy button?
Interesting question, I never noticed that (perhaps since I usually use a watch window). I find in 9.4 I’m seeing the same thing, but only with “Numeric Variables” and “String Variables.” The other types of variables remember where you moved that window to last time you looked at one of that type, which is how I think the Numeric and String Variables should work too, do you know I mean? Agree?
Agree. It should remember where you moved the window last.
