Using Opto22 Hardware, i am able to create SNMP packets which i use to monitor multiple devices.
I am creating a script wherein, if in between requesting the parameters of the SNMP device, a communication loss or data error happens it will create an error log.
Unfortunately i happen to encounter that if the physical connection is not established, multiple error log will happen.
What i want to do is to check if a connection is established first then skip the whole SNMP parameter requests.
Using OpenOutgoingCommunication and IsCommunicationOpen command does not seem to solve the problem, it seems as though a connection is walys open.
Since the PING chart that was provided by Opto22 is not compatible to SoftPAC.
Is there a way to do this my manually creating the packet?
hoping anyone can help me.
Thanks
