I know that PAC R1 controller require a static IP address, but I am interested in also giving it a hostname. It looks like the only opportunity to give it a hostname is when you are giving the PAC R1 a IP address for the first time. PAC Manager instructs the user to leave DNS and Hostname blank when assigning a static IP address the first time. Is that because that is the standard set up? I don’t see how to assign a hostname after I have given a PAC R1 a static IP address already. I assume that the hostname will be seen on the network as well as the IP address, correct? Thanks, Kosmos
