If there was someone with little work which I doubt very much it would be great to have a groovFinder in java or similar to be able to search for groov devices from OSX. Many times I have to start a virtual machine just for that. Please…!
Will it run under WINE?
No, it does not run.
Maybe someone from Opto can share the groovFind protocol so someone can write their own utility. All I know from sniffing the network is that it sends out a 1024 byte UDP packet to port 2022 (IIRC) and waits for a response. The contents of the packet are not consistent.
Ok, this is minimally tested, but it works here in the office: groov Find.zip (218.7 KB)
Importantly:
It works perfect! Thanks a lot!!!
