This one’s a little bit weird in that R4.0b only shipped on the GRV-EPIC-PR1’s version 1.0.1 system firmware, so there’s no separate R4.0b release. (QA is a little swamped right now. :D)
You can find the new version of groov View or groov Server for Windows by logging into your Opto22 account through manage.groov.com
groov View R4.0c
June 20, 2018
Bug Fixes
KB87516 - Mobile devices will not re-subscribe to tags after sleeping for several minutes
groov View R4.0b
June 18, 2018
Bug Fixes
KB87475 – Gadgets report error messages when scanning OPC-UA devices while running groov View with an expired license
KB83992 - groov View cannot connect to a OPC-UA server after the network connection is lost and then recovered
KB87477 – Value scaling not working on Round Gauge, Range Indicator gadgets
KB87478 – groov View fails to run and returns a “503 Service Unavailable” message
KB87496 – groov View erroneously shows that it’s entering trial mode when running with an expired maintenance
(Note: I don’t think KB87496 is up on the website just yet, but it should be soonish.)
I don’t have a server license, but I use the demo on my dev machine for development/testing - is the demo version going to be made available again for download?
1.I want to know where to download the Groov view App on the phone.
2.Groov Server for win R4.0C version of my test is still the same question. Am I mistaken?
It seems to be more serious. You must stop before you start Groov server (using Groov monitor).
3.Can I use R4.0 to develop projects that can be imported into R3.4C? R3.4C does not seem to have these problems.
Johnathan,
When are bit operations in Groov going to be introduced?
This greatly limits the things we can do on Groov.
I have a client who I taught to start using and building his own screen then he wanted to include the alarm defeats/indication and of course not doable unless I go in and add all those vars or a table etc.
Reading bits from an integer register is actually becoming more important than ever when using the Ignition Edge module to connect to PLCs connecting to groov VIEW though the OPC-UA server. The limitation of 500 tags becomes a real restriction as each bit needs to be separated and declared as a separate tag before it can be meaningfully used in the groov VIEW interface. Appreciating that “behind the curtain work” is needed to apply optimization on the requests in order to avoid requesting the same register multiple times for different bits of the same register, but I still think its a valuable improvement that’s worth the effort.
