Hi, I would like to know if it is possible to perform an HMI with pacDisplay which deactivates the communication of a SNAP-ODC5-iFM output module and force the signal in the XVAL to a 24VDC solenoid. This idea is to not manipulate the PACControl, disabling the communication and forcing the digital output in the XVAL. What I can do?
I have a SNAP-PAC-S2 controller which communicates with a SNAP-PAC-EB1. The brain is installed on a SNAP-RACK-16-FM and has SNAP ODC5-iFM digital outputs. The idea is to activate and de-activate solenoids, but sometimes for reasons of program logic, the solenoids maintain a value either ON or OFF, and for testing purposes I would like from the PAC Display to disable the point and activate and deactivate said solenoids. This is very easy from the PAC Control, but it is required that it is not manipulated.
