Digital Output Using pac-manager
#1
Hello every body quick question I have a rack with 16 ODC5-i modules(Digital Outputs) on it normally I am able to turn off or on any particular digital output point in fact I can manipulate all of them on this rack but I have one of them that wont let me turn it off for some reason it is always on I’m using pac-manager to communicate with my rack…any help would be appreciated thankx
#2
When you click on the menu on the left, ‘Digital Bank’, do you see anything unusual?
Also when you say it will not turn off, does it have a load, or are you talking about the module LED?
Have you tried swapping that module with another on the rack to see if its the module, or the position on the rack?
#3
What do you mean by unusual?? and Yes Beno I already swapped that module but still is always on this particular one is channel number 1 but channels 2,3, and 4 are fine even with no wires connected to the Module it is always showing “ON” on my digital points screen on PAC-manager and when I push the “OFF” button wont work the rest of the modules work…thanks for the quick response Beno
#4
here is a screen shot of it
