Just purchased a Groov Epic training unit. After setting it up, I loaded a small strategy so I could test communications to Ignition 8.0.10. After cycling power on the Epic, the strategy was gone, and Groov Manage reports that the memory has been cleared. My question is: Is there a way to prevent strategy loss after a power cycle?
Then click on the download tab and check the top option and others as you see fit. (This check box is the key - the most important option to check).
The second check box here is very helpful as it means that the strategy will auto run when the controller powers up.
