Hi, I’m very new to Opto22 and trying to get some analog values to Ignition for trending purpose. I’ve looked around but can’t seem to figure out what I need. Basically, at this point all I have is Opto22 connected IP address and the tag names. How do I go about getting Ignition to get those tags ?
Hi S007.
The Opto 22 SNAP PAC Driver Module for Ignition is a product from Cirrus Link Solutions, and the instructions to configure and use the driver are on the Cirrus Link website: https://docs.chariot.io/display/CLD/Opto+22+SNAP+PAC+Driver
Hi GrayChurch, looks like version 3.3.2 doesn’t work with earlier Ignition. My Ignition version is 7.8.4 and after I installed the module it says “Faulted Minimum Ignition Version Not Met”.
I’ve got an update from Cirrus Link: To use their Opto 22 driver, the minimum required version of Ignition is v7.9.4.
They’ve posted the supported versions on their website: Module Installation - MQTT Modules for Ignition 8.x - Confluence
Be aware that in their chart, an X means Not Supported.
Gray
Excellent! Thanks for the update. BTW, how are you using Ignition + Opto 22? Got some screen shots of that “Trending” you mentioned? Have you used their reports at all? We’d love to hear as much as you can share!
