National Instruments has a machine vision program called Vision Builder for Automated Inspection that offers many of their vision inspection features at a fraction of the full LabVIEW+Vision Module development system cost. In practice, VBAI runs best when it is on a dedicated computer, so that its resources can be focused on image processing and analysis. The results of the image processing would be useful inputs into an Opto22 strategy that controls the equipment on which the vision inspection system is installed.
VBAI offers the following methods to transmit information to another device or program:
You can use IO lines, if you have a DAQ card.
Standard TCP or Serial communication using the TCP or Serial I/O step)
Ethernet/IP (VBAI 3.6.1 support unconnected messaging)
Modbus
Serving data using OPC
My strategy is running on an R1 controller with a 16 module rack that is not yet fully populated. I would like for it to be able to send basic configuration infomation to VBAI (part number codes, on/off commands), and also read the results of the inspections (some discrete, some values).
The DAQ card option is probably the fastest and simplest, although the DAQ would have to be NI brand to be recognized by their software and used properly. Sending more than 2 channels of analog data by this method would get very pricey.
OPC would be relatively fast. VBAI’s preferred case would have it function as the OPC Server, and Opto22 as the client. Is that possible? Based on what I’ve been able to determine from the online resources, PAC Display can only function as a client to an Opto OPC Server. With OptoOPCServer software, it might be possible to talk server to server, but that will incur software costs on both sides (Opto and NI).
I’m not sure how I would use Ethernet I/P to communicate, leaving direct serial or TCP, or Modbus. The advantage of Modbus is that the data persists in registers even if the message is lost. The strategy would act as the master and VBAI the slave. The VBAI registers can be read or written to as needed by either application, without worrying about whether or not the data is needed at that moment. By having a defined register for each tag, it is possible for PAC Display recipes to reliably control VBAI parameters.
As an added bonus, multiple instances of VBAI can be open on the inspection machine (distributing the machine vision CPU load), and they all share the same Modbus registers. This allows the instances to talk to each other, as well as to the Opto controller.
The Modbus integration kit will speed up the programming for this considerably. Thanks for making it available.
Jason
