Hi All,
As you’ve probably heard us talk about in this video on writing good code that Ben & I did a while back, comments are very important.
There are the green comments in your OptoScript code done using // or /* comment */, you can add comments into your blocks, and you can also add text directly to your chart.
But there’s another way of adding some notes to a chart that can be handy too – just use an empty block like this:
You can then use a connection line to draw an arrow to a block you’d like to point out, and you can also change the background color (which you can’t do with the standard text box tool).
Neat-o!
