Best way to detect if communications is lost between Controller and Brains
Hey Watchdog Fans,
For those of you wanting to keep track of PAC Display (if it’s still running) from within your PAC strategy, I tried out PilotMan’s suggestion of using the Alarm features in PAC Display. It was nice and simple and worked great! Here’s how I implemented his idea:
I have some looping OptoScript with two int32 variables used with PAC Display, and a string to show the current status.
  // Initialize the value that PAC Display should set to 1
  nPAC_Display_to_Increment = 0;
  // set the flag which to trigger PAC Display Alarm point
  // to cause increment on nPAC_Display_to_Increment
  nPAC_Display_flag = 1;
  DelayMsec(2500); // allow some time for the communication between the PC and PAC
  if ( 0 == nPAC_Display_to_Increment ) then // nothing happened
    sPAC_Display_Status = "PAC Display not responding";
  else
    sPAC_Display_Status = "PAC Display ok";
  endif
  nPAC_Display_flag = 0; // clear the flag
  DelayMsec(2500); // we'll only check every 5 seconds, so allow the rest of that time to pass
For those who prefer action blocks over OptoScript, here’s a block-based chart.
Here’s the exported chart you can import if you want to save some typing:
PACDisplayMonitor.zip (1.78 KB)
In PAC Display, I selected:
Configure > Alarming Setup > Alert Window [tab]
UNcheck “Enable Alarm Point Alert Window” as shown here:
Configure > Alarm Points > Add.
Give it a name, select the nPAC_Display_flag used in above OptoScript
In: Setup By, choose Discrete
In: Notification Options, Check Alarm Enabled.
Click on the Alarm button, in Current Value choose Set, value out: 1.
Click the ? to choose the value to change (nPAC_Display_to_Increment as shown above). Click OK to close.
Click the Discrete tab, choose True/On.
When I had this all set up and running, watched sPAC_Display_Status changes as I started then stopped PAC Display. Neat-o! Thanks, PilotMan!
-OptoMary
p.s.
Here’s a little video snippet showing what this looked like in action:
