I’ve been given a project to get Opto22 PAC Controllers talking to BACnet equipment. I’m slowly learning BACnet. I downloaded the Opto22 BACnet/IP integration kit and didn’t have much luck getting it to work with my initial setup which includes a an Opto22 PAC R2, a Fieldserver router and a Johnson Controls stat. I then noticed the code submitted by Nick Stephens a few years ago and downloaded that to give it a try. He had posted two subroutines, one for discovery and one for reading multiple points. I got the discovery subroutine to work although its a little odd. It will discovery 5 of 19 points very quickly but it will take a couple of minutes for the rest of the points to be discovered. The read operation still doesn’t work. I converted the read subroutine back to a chart last week and seem to get the same results as with the subroutine regardless of various small changes. So I fired up Wireshark to look at the packets being generated. Every TransmitString command seems to result in two similar but slightly different packets. I also get replies to both packets. On the discovery packets I can see the points coming back. I am not seeing any errors from the charts or subroutines.
So two questions:
- Can anyone tell me why I am getting two packets for every TransmitString command?
- Anyone with any further tips regarding BACnet on Opto22 hardware?
