The “+” operator is actually a different instruction for strings than it is for numeric values. It is the Optoscript version of “Append String to String” and “Append Character to String” commands.
I imagine the limitation of not being able to concatenate strings in command parameters is due to the way memory is allocated for strings - with an integer or float the result gets placed on the stack like a literal so it’s no big deal (it’s 4 bytes (or 8) no matter what happens), whereas a string concatenation the result needs to have memory allocated to it due to a strings varying length. Since Optoscript has no dynamic memory allocation, there is nowhere for the string result to be stored - so you must assign the result to a variable, which is essentially a compile time memory allocation of whatever size you defined the string variable.
What is really annoying is you can do things like this:
